gbarbosa1982
Thread starter- Joined
- Oct 18, 2015
- 14
Issue:
Port side engine does not start. It clicks, but doesn?t crank.
I believe that it does not have a ?slave solenoid?, but a Relay instead. When I tried to turn on, the ?click? came from the relay, which I replaced, but the issue remains the same.
Items that I was able to check:
- Battery is fully charged
- Start Solenoid (attached to the starter) is functional - I was able to individually jump it and it moves
- Starter is functional - I was able to individually jump and it spins.
- Throttle is on neutral position.
If terminals A and B are jumped (pic attached), it cranks but wont start. If the ignition switch is held in the ?on? position and A and B are jumped again, the engine turns on, but if the jump is removed or the ignition switch is released, the engine dies.
Any ideas about the root cause?
