- Joined
- Mar 8, 2009
- 43,913
Your not going to damage your motor with running it a bit to rich at idle. Being out 2 turns is reaching the point, but having it much farther out and if it does not improve then it's still the carb in my opinion. Air needs to flow across the throttle plates enough to turn gas to vapor, not enough air, it doesn't work right.
Since everything you check is correct (idle rpm, compression, timing, plugs wires, cap) and you don't have a vacuum leak, only thing left is the carb. So if this doesn't work, its back to the carb IMO
