Hoosmatroos
Thread starter- Joined
- Jul 11, 2011
- 250
Yesterdag, when we pulled the boat out of the water to put it in storage, I asked the club members to put it on a pedestal and leave it outside for 30 minutes so I could drain my block first before put my boat inside. Removed the hoses from the manifolds (no drain plugs there), removed the big hoses on the thermostat housing, removed the drain plug on port side of the engine (water was only dripping, even when poking) and then, tried to remove the drain plug on SB side but the SOAB broke and left me with the thread inside the block. Luckly the plug is hollow so the block drained for 10-15 minuten and should be empty.
Try to remove the left over thread in the next couple of weeks. Will try this with a left handed bolt remover (don't know the actual English word for it
) It's a pita to reach that spot. Ordered all new plugs (22-806608A 1) because the one broken looks dried out.
If you have any comments, please do. Otherwise I'll make some pictures on the way and place it here to help others.
