SWBuechler
Thread starter- Joined
- Sep 14, 2015
- 27
So, the continuing saga of Tweedle Dee and Tweedle Dum. We put the outdrive back on and everything is fine. The drive is in forward gear (we never moved it). The lower unit seems good, the prop only moves in one direction. Everything's GREAT!
Then we decide we should have replaced the impeller and water pump in the lower unit so off it comes (leaving the upper unit installed and in gear) and we replace the impeller and water pump and re-install the lower unit. NOW THE PROP TURNS BOTH WAYS!!! What did we miss during installation? Are you suppose to turn the gear rod in the lower unit a certain way while re-installing? Do I have to take the lower unit off and make some sort of adjustment and then reinstall? Can I just take it out of gear and put it back in gear? Help please.
