rolmops
Thread starter- Joined
- Feb 24, 2002
- 5,751
Or so I think.
Last week my gimbal bearing went kaput and 2 days ago after the new one had arrived I decided to take the gear housing off and replace the bearing. It was supposed to be quite straight forward except that it was not. I took the six bolts off without any trouble but beyond that nothing wanted to move. I poured lots of wd40 into the small slit that did open up but that did not help any either. So I cut the bellows open to see what is going on and I found out that the u-joint is in good order and straight. Then I loosened up the bell housing. This enabled me to move the gear housing back and forth because now the bell housing moved back and forth.
Long story short. This is my question. Is there a way to loosen this thing up or must I remove the engine and hammer the drive shaft out from the front?
thank you for your thoughts and opinions,Cornelis.
