1lastweekend
- Joined
- Nov 7, 2015
- 68
This fall I decided to replace the worn interior of my 81 Rinker. I removed the seats and some of the carpet and then removed the interior vinyl/plywood sidewalls to make templates for the new pieces. I found some rotten wood under the fiberglass sidewall structures (not sure what the right name is for this area!) and removed most of it, but the area in red is rotten and will have to come out. I plan to cut out the area with a sawzall or vibratory cutter, then insert new plywood and glass it over. I have never done glass work before, but have been doing some net research on how to perform. The rear of the floor on the boat is open so I checked the stringers, they appear to be solid and not rotten. The motor mounts and transom are also in great shape. The floor itself is also solid. Any advice or tips on how to perform this repair is really appreciated! Here are some pics I took:
