- Joined
- Mar 8, 2009
- 44,638
Good thing I back the truck up yesterday and left it running, I heard a slight noise under the hood, couldn't hear it inside the truck. Turned out the clutch end plate was laying on the fan shroud. Appears the bolt had broke off. So I have a small maybe 3/16 diameter stud sticking out the end of the compressor shaft. It's in a tight place so getting to it will take some doing.
Also trying to figure out how to hold it to remove the rest of the bolt/stud. Some research shows it may have up to 4 shim washers on it. Could use a breakdown of the parts so I can figure out what needs to be replaced, and if I can get it done. Not bad for 129K miles without much issue until now.
Good thing it's getting cold, no need for the AC
