Well, a full restoration on a typical 20ft boat will usually require about 6 sheets of plywood. At that price That would be a little over $500 bucks for the wood. If you bought the cheaper Ext. Grade at $35 bucks a sheet and used Polyester resin, the savings on the wood would pay for approx. 10 gallons of resin. Some guys need to budget for their boats in such a manner, others want the "BEST" of everything. To each his own. I think it's important that we try to show everyone ALL the options so they can make the best choices for their situation.I paid $94 plus tax for a 4 x 8 sheet of marine 3/4 fir. It was 7 plies, good stuff. Compared to the labor the cost of the wood is almost insignificant.
Well, a full restoration on a typical 20ft boat will usually require about 6 sheets of plywood. At that price That would be a little over $500 bucks for the wood. If you bought the cheaper Ext. Grade at $35 bucks a sheet and used Polyester resin, the savings on the wood would pay for approx. 10 gallons of resin. Some guys need to budget for their boats in such a manner, others want the "BEST" of everything. To each his own. I think it's important that we try to show everyone ALL the options so they can make the best choices for their situation.![]()
As long as we make it clear that these options are not equivalent and they DO NOT accomplish the same results.
All of the real strength comes from the glass and resin.. You can, if you chose to, build your stringers out of cardboard..
That's a bit misleading. You can certainly build stringers that do not require any core, but most of the boats people are repairing here rely on the core for some portion of the load bearing. It's a cheaper way to achieve the same net strength.
Not trying to mislead anyone here.. Just a comment...
