bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
I have just mounted my 1997 Johnson Fast Strike 175 onto my starcraft. I rigged up two fuel tanks under the floor and have a T valve to pull gas from one, OR the other. I ran the outlet line to my fuel -water separator. then I run the line to the BULB and then into the motor.
now I have a similar set up on my V4 and a few years back I think someone said I might have added too much restriction when I added an IN LINE fuel filter as well.
since both my new boats gas tanks were hand me downs, and since they sat around for a year or so... I suspect( even though I cleaned them) that I might have some debris...sooo I want to at least add a temporary paper in line filter.....but will this set up restrict the fuel demands of the V6 175.....
also is there any type of debris filtering going on in the tempo separator????
thanks
BOB
thanks
BOB
