reiddo1
Thread starter- Joined
- Jan 17, 2012
- 166
Largely because of what I have read on this site, l am led to believe that I have excessive prop slip. My WOT engine speed is 5200 RPM and my GPS boat speed is 36 miles per hour. The engine is in excellent mechanical condition and according to Solas the 14.5 by 19 pitch prop is theirs from the number on the prop hub. Since I can stand on the prop blades and turn over the engine with all the plugs installed leads me to believe that I do not have a spun hub and indeed the prop is like new. I have raised the engine to the top hole and do not have much trim range at WOT before it starts to ventilate. The anti ventilation plate is about 1 inch above the bottom of the keel. This last position has been arrived at one hole at a time and I will probably keep it there for some time.
I have read where in cases like this, a prop with cupping can get around this slip issue. Is there a prop which will reduce my slip and improve on my top end. Hole shot is absolutely superb with up to four onboard with full tank and fishing gear. The number on the current prop is 390821 and my lower unit ratio is 1.86 to 1. Any comments are appreciated.
