Challenger84
Thread starter- Joined
- May 9, 2010
- 341
I've been doing some research and cant find anything on installing a heat for my father's boat..
I'm thinking about using the cooling system from the engine to produce the heat.
Example..
Install a "radiator" inline with the cooling system.
My thinking was to run the line from the cooling system where the HOT water exits the boat and have it go through a "radiator" with a fan on the back of it to blow the hot air through out the cabin and have it back to the cooling lines a little cooler to exit the sytem..
I'm not sure if i am explaining this correctly (which is maybe the reason i can't find anything on it)
Has anyone done something like this?
Is there something out there that would make doing this easier?
Any draw backs with running a system like this?
Example..
