sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
I have decided to go with a remanufactured powerhead. Dont have the time to fool with the old block right now, and just want to get back on the water. If I ended up doing a rebuild, I would have wanted to replace all bearings, pistons, etc. to avoid another failure in the near future. So I decided to get an OBR powerhead and keep my old motor for parts if I ever need them. Here is what OBR recommends doing in addition to their break-in procedure:
Install .002 larger main jets in carbs.
Retard max timing 2 degrees. Set max timing with engine running over 4500rpms under load, do not set max timing static.
Replace waterpump.
Install water pressure gauge.
Use mid-grade octane with no alcohol.
Remove oil injection (at least replace to latest VRO).
Double your oil.
Retorque cylinder heads after 10 hours.
Rebuild fuel system.
Check overheat alarm.
Most of this is pretty understandable. Do you guys overjet the carbs with rebuilds/remans or is this an odd practice? How do I get jets that are oversized, do they have them at shop.evinrude?
I use Joe Reeves WOT timing method. Is this not permissible? Also, should I keep the timing 2 degrees retarded?
Is breaking an engine in during the cold months a no-no? Water temp is in the 50's right now. Air temp is 30 in the mornings and 50 during mid-day. Maybe that cold dense air is not a good thing for a fresh break-in?
Replace waterpump.
Double your oil.
