- Joined
- Mar 8, 2009
- 44,681
Was doing some more prodding and thought I had a bad connector on the trailer as when probing the brake light (blue wire) on the vehicle side connector I was getting no light from test light (as expected with only the hazards flashing) and ground side of test lamp was connected to same ground point on the trailer as the harness. Once I plug the trailer side into the vehicle i was getting a pulse from the blue wire.
Quickly spliced up a new trailer harness connector but still same issue. I also tried connecting just the ground and yellow but same result clicking solenoid no tail light/turn signal.
Going from your post 5
I think you either have something mis-wired or the vehicles tow package circuit has a problem. To restate some items;
There should be no blue wire being used for any of the lights on the trailer. The trailer is just used for the reverse brake solenoid.
You should not be using a 4-prong connector for this trailer unless you have an additional connector just for the blue wire.
Straight 4 wire trailer wiring is shown on top.
