dingbat
- Joined
- Nov 20, 2001
- 17,310
The problem with an in-hull is two fold. Your loosing power thru absorption and introducing a frequency switch.
3db is typical used to calculate the peak response plateau. On a low "Q" transducer you could have a max. sensitivity window of plus or minus 2 kHz.
The frequency shift of a signal passing thru a hull is well documented http://www.airmartechnology.com/uploads/installguide/In Hull Frequency Shift.pdf
