64osby
- Joined
- Jul 28, 2009
- 6,826
Yes this one has 2 live wells which I don't use, but it is low when I'm going slow or especially when I throttle up to go on plane but once I'm on plane it seems to be fine.I think you should recheck your capacity plate. It should read Max Cap XXXX or X persons not to exceed XXX. Also what is the max HP rating for this boat? I find it hard to believe that you are at or near capacity of this hull as I've seen too many of these boats that are running larger engines and some even come with live-wells in them..
I get 697 lbs from the console back. Motor is 177 lbs.
Hole shot must have been pretty slow?
If it is the boat in the link or one like it it is a Fishmaster 16'. 6 persons 750 pounds. 40 hp for one model, 60 hp for others. ***(1990 info is the closest I can reference)
I would take it to a scale and try to figure out the weight of the empty hull.
How many boxes of shells?? I think weight distribution, as above -- but also would still suspect water logging under the flooring. Unless absolutely ruled out, potentially huge weight issue.
How does it sit in the water when there is no one in it, just gear?
I was wondering if your model of SC has a splashwell in front of the motor. My 16' SN rides about the same and I've never taken water over the transom. It rides up and over the waves / wakes.
The stern of my little 16' SN has all the same things, fuel, battery, livewell and big guy in a seat. I really think it's much ado about nothing.
It is a bit tilted at the Sturm but it sits kind of high...
From the picture you posted everything looks fine and normal to me. Again you may think of moving your passenger more forward to help level out the boat and to take the weight off the stern.
Those boats have a shallow freeboard anyways and will always look like you're sitting right on the water, especially if you're coming off a big boat.
