drun_trucker
Thread starter- Joined
- May 24, 2015
- 52
So some time back I posted or asked about swapping out a marine motor for an automotive. After a bunch of trouble I got the auto motor swapped out. I got it timed and ran fine in neutral. However when under load it would get over 2100 rpm (that was still on the trailer at the launch). On the lake I get up to 3000 rpm.
After have gone over just about all I could think of I deduced it must have been the auto cam...
Therefore I fixed the crack on the marine block and began putting that back together, fast forward a few days and here we are again. Motor is back together and in the boat. It ran like a top prior to removing except for taking water into the block. I got that problem fixed but now I'm back to no power.
I am thinking that I must have an issue setting valve lash. I even did that to spec in the service manual.
Please please please, throw some ideas and questions at me.
Fuel is good and filters are new, compression is great, spark is fine. Timing is 8* BTDC, advance is 22*, all ALL other components are original to the application that ran perfect prior to removal.
