clueless75
Thread starter- Joined
- Jan 30, 2015
- 102
So I took the boat out to the river yesterday only to find that when I start it, it only lasts about a minute at best. Fuel tank is full, fuel primer bulb is hard, fuel tank vent is open, no fuel leaking anywhere... I'm clueless! (Hence the name). I got this boat through a trade for a go kart (of all things) and there were many problems. First, all the wiring from the internal wiring harness needed to be redone (which I did by splicing the wires near the bottom since a new internal wiring harness would cost over $300 or something ridiculous), both carbs leaked (which I fixed by replacing with new floats, although one valve was a little sticky sometimes), and the wire from the coil to the distributor was barely hanging in there which actually fell out later, so I had to replace that as well. Yet somehow, it miraculously started when he showed me. Anyways, I fixed all of those things and here I am, without it running very long at all. When it starts, it's at either full, half, or no throttle and runs fine for a bit then misfires for a second or two, sputters, and dies. Also, if it runs and I try to accelerate/decelerate it will do so for a bit but will also die. It seems as if it's on a timer to just give up after a minute haha. Any help would be appreciated to solve this mystery, thanks guys. (the pictures didn't turn out good but oh well)
