BBC build- Don't tell the Admiral
This would be the 7th electric die-grinder that smoked on me. its now out of its 90 day warranty
these are the final result. will be mounting to the motor to figure out the bracing
they say, if it doesnt go, make it shinny.
going to mount the side exhaust tips, re-gel the bilge, then get the motor in to finish the exhaust.
because I have the gel and the gun to shoot it.
Impressive, Scott. Nice stuff.
Thanks. currently spending evenings sanding the exterior of the hull to spray new gel. pulled the transom shield off yesteday. used 3M4000 UV when I bedded in all the bolts. took me about 4 hours with a ratchet strap and wood shims to get it to come loose
Tail_Gunner
Well say something.....or have you lost the bug a bit. LOL Gezzz can you move this along.
