goblerblaster
Thread starter- Joined
- Dec 26, 2011
- 180
Got the motor un-locked and running good after carb kit, points, coils, impellor, etc. NOW, how is an easy way to get the hood on? It is so nice I hate to scratch it up, but I can't seem to get it on without scratching side hood on the gear shifter. I have to unscrew the high and low speed carb adjustment screws and take them out of the carb because the small screws that hold both knobs on the brass stem are stripped and I can't take them off. Do you put the hood side opposite the gear shift on first or the side of the hood that is on the gear shift side first? Seems like I read one time that it is easier if you put the gear shift in reverse??
Thanks for any suggestions......still trying to find the sweet spot for the initial start after the engine has set for a couple of weeks. I usually have to use starter fluid and about 20 pulls to get it going. After that, it will start first or second pull all day long. any ideas?? There is gas in the glass bowl on the bottom of the carb and I can see gas running into the bowl when I pump the button on the gas tank that pressurizes the tank. Spark is good.
