2hp adjustment
jerryjerry05
Working on the neighborhood kids 2hp Evenrude. It has 2 adjustment screws.
​Mod E2RCTD E0165053
The top is slow speed and bottom is high speed.
Any links on adjusting? Any help would be appreciated.
flyingscott
1.5 turns on each will get you started. Then adjust further when it's warm and running.
fhhuber
Need to get out on the lake... You can't get it really correct running in a bucket or on muffs.
If in doubt at all, open the needles more. Too rich runs poorly. Too lean burns up the engine.
Low speed needle needs to be purposefully rich while adjusting high speed.
There's a potential for getting the low speed needle too lean and the high speed needle not working correctly if you don't make sure the low speed is too rich.
Let it rip and adjust for max speed then open the needle about 1/16 turn.
Then you adjust the low speed needle for slowest it will stay running reliably while in gear.
flyingscott
One other thing I would check is compression they wear out fairly quickly if they are used a lot.
oldboat1
Hi Jerry -- initial idle settings shouldn't be much different than Chryslers, where appropriate. From lightly closed, open l.s. needle counterclockwise 1 1/2 to 2. Open the h.s. needle about 1 turn. Assuming the carb is clean, flow from the tank through the valve is good, and pumping water OK, let it warm up a little at idle or fast idle using the initial settings -- wherever it starts and runs. Object is to lean the idle mix as lean as you can with a low idle and no lean sneeze. Typical procedure is to throttle it down as low as it will go, lean the l.s. mix (rpms will increase), then lower the throttle a little more until you hit a low idle, running smoothly. 650 rpms in gear is pretty standard across the board, but I go by sound.
You can run that little unit in a barrel or similar container to get some back pressure. A plastic trash can works well for me with the little ones. The engine will stall at idle if the air/fuel mix is too lean. As you know, it's not the same issue as an overly lean gas and oil ratio. Low and slow is the object, leanest setting to achieve that. The h.s. setting will end up around 3/4 open in my experience. Should be able to throttle up and down without stumbling. You can get it very close running in a barrel with the 2hp, and the kid can tweak it a little when he's got it on the dinghy -- Good kid's motor. Don't forget to open the fuel shutoff.
Stumbling signals too rich. Lean sneeze is too lean. Correct setting is somewhere in the middle between those extremes. There's a couple of stickies around (Joe Reeves and others), but it's standard stuff. Not sure if the single cyl. 2 is much touchier than the small 2 cyl. J. and E.s -- early 3's run like sewing machines.
[ed. good to snug up the jam nuts for him when you have it dialed in. 1/8 turn one way or the other can spoil it, and don't want the needles to rattle loose or have the kid whipping them around.]
jerryjerry05
Joe gave me instructions on another site.
​The motor is used on a canoe and I am way to old to get in and try to adjust this in that kind of boat.
From another site.(yes I cheat)
(Thanks Joe and Kim.
It had water in the fuel and the boy who owns it started messing with the screws.
The water was the first thing I checked for.
Changed the fuel and sent him out.
Still wouldn't operate right.
Finally after talking to the kid I realized the thing was probably overheating and pulled the lower and it needs an impeller.
But he still messed with the screws and the info you gave will help get it running right.
Thanks,Jerry)
