bob johnson
- Joined
- Feb 25, 2009
- 4,306
My Johnson V4 1995 vintage ocean runner 115 hp has had the straboard side plug bodies rusting badly while the port side has no rust. I use the motor in salt water, maybe 20 times a year... I am thinking it MIGHT be because the port side runs much hotter at idle than the starboard side, and thus the heat removes more moisture...at cruise both heads are the same 100 degrees...
do you guys think the reason is the temps??? or is there some type of electrolysis going on I don't understand?? there is no leak in the cover!!!
bob
bob
