Phunahm
Thread starter- Joined
- May 5, 2008
- 39
Hello I have a 86 mercury 150 xr2 SN 0A933978 Ive had an issue with the Idle/hole shot for years....Idle surging between 700-1100 rpm and bogging on hole shot....Here a list what Ive done to try and fix..... IGNITION*** Stator,rectifier,regulator,CDI switch boxes,plugs,wires,Idle stabilizer was removed and timing set to 23* Checked spark on all Cylinders sync and linked numerous times.. Marked flywheel for all cylinders for TDC to check for fluctuation, BTW i wasn't throwing parts I did have a bad stator charging side,, Fuel System*** Rebuilt carbs,replaced all fuel line from tank to engine including a filter,rebuilt fuel pump. Misc** compression is 120 on all,I replaced all bleed lines and valves and verified they were in correct orientation. Hole shot issue**** I dropped to a lower pitch still bogs was a little better but still there...upper rpm performance is great.**** I decarboned using sea-foam and gallon mixture with second can,,,,,,,,Now I pretty confident the ignition is working properly ,so I was looking into the fuel system again yesterday it was idling with muffs on and surging as usual so a pump bulb make sure it was hard it was,, but I felt something when the engine missed while idly the bulb went soft for a moment then back to hard did this every time it missed...... Does this sound like a reed issue? Thanks for any input
