- Joined
- Mar 8, 2009
- 42,552
Does decking mean flattening the area where the heads are bolted on? Do I need to know which piston I want to use before this is done?
The deck is the flat area where the pistons are and the head sits on top. The factory deck on a block is a bit higher then the height of the pistons when they are at Top Dead Center (TDC).
The normal method of decking a block is to shave the surface down to where the top of the piston is at the same level as the deck, called 0 deck. If the deck is higher then the pistons, this is in the positive side (exp 0.010 deck), if the pistons stick above the block, this is negative deck (exp 0.005). The zero deck is what is most often used.
Then if you have a 0 deck and use a 0.040 or 0.038 head gasket you have your quench (0.040 or 0.038)
To add on to the piston responses, if you use pistons which are taller then factory, you will want to deck the block less or maybe none. So as Scott mentioned, don't start cutting on anything until you decide what components you will be using. crank, rods, pistons, and if head or block needs to be flattened
