News to Me
Thread starter- Joined
- Jul 17, 2011
- 22
The manual does say to use it and I have done it both ways based on advice of some reputable repair people. The last bellows I put on does not have any on.
You are probably correct. My drive says to use it but the newer drives likely don't. Mine has the groove too. DonS said you didn't need to use it on any of the drives. I think I used it once.Hey Bruce, I'm not sure if that's a typo or if you are talking about a different drive, but the SX-A/DPS-A manual does not say to use adhesive. Bellows install is on page 179 here:
http://boatinfo.no/lib/volvo/manuals...rive.html#/182
Hi there,
Did it 10 months ago on my dps-a with new bellow and 5200 sealant before tightening the clamp in the transom shield.
The boat is year round in the water...
10 month later, there's water in the bellow. The u joint is shot. Had to install a new one.
So this year I also used 5200 on the lip that goes in the pivot housing. Hope it will do.
The design is really crappy imho.
Yes, it won't be easy to take it off. But if it saves me another u joint change, it's gonna be worth it ! Time will tell !
Only if you don't know what you are doing.The problem is when you go by the book (i.e. no sealant, everything cleaned up and torque screwed ), water seeps inside eventually.
Get rid of that 5200. Buy an OEM manual. If you follow the procedures in the manual, you won't have a problem.Interesting... Maybe you could help ?
Except that you used 5200 sealant.Already did that. Leaking all the same.
