findinghomer
Thread starter- Joined
- Nov 7, 2009
- 379
Alpha one Gen 2. Long story short, I had to replace the bushing bc of a broken speedo connector. I wish I had researched first , but it seemed pretty straight forward. I didn't, Yikes. Here's what I did. I turned the L connector straight (forward gear) pulled shaft assembly out, swapped assemblies. Reinserted shift shaft back down into lower gear housing. Then later I find out i could have knocked my shift cam out of place. Now I'm worried bc I wasnt careful I didn't know it was that intrical . Pretty sure its not right. With it all back together, if I turn the L connector straight forward, the unit locks into forward, when I turn the shift shaft to my right it locks into reverse, middle neutral. But shouldnt there be some spring tension to it, and also, shouldnt counter clockwise (when looking from the prop side) be the way you would turn it for reverse? Please help, thanks guys!
