Can anyone tell me what year and hp this motor is?
zackduncan40
I recently acquired an outboard motor and I was told it is a Mercury but there is no way to tell because they have painted over everything on the motor... The only numbers I can find on the motor are 1497-8793.... Is this enough info to tell? Or where else do I need to look for numbers? Thank you!
That set of numbers appears to be a casting # off one of the parts on it.-----Post a picture of your motor.
zackduncan40
Mercury Motor year? HP? Specs?
I have a mercury motor that i have recently acquired and i was just wondering if anyone on here could tell me what it was by looking at it? the person i got it from has spray painted it and i can't find a serial number on it anywhere. and also he said it had been winterized.. what does it mean to have an outboard motor winterized and how i de-winterize it? Thanks!!
GA_Boater
I guess you forgot that you stated a thread earlier. Moved your new thread into this one. Please do not start multiple threads on the same issue - One thread is enough.
Where are the pictures? You need to give us something to work with. As you can see - the Official Forum Crystal Ball is in need of repair.
zackduncan40
No Title
zackduncan40
Can anyone tell me the year and hp that motor is? And if it is a 4 stroke or 2 stroke? What gas:eek:il ratio I need to use? And how to de-winterize it?
GA_Boater
What numbers are stamped on the circled welch plug? And what does the sticker on top of the flywheel cover say?
flyingscott
Roughly 84 - 86/87 25 hp mercury 2 strk 50-1 gas mix. Winterize by running out of fuel spraying fogging oil into the motor and change the lower unit lube.
zackduncan40
That sticker is on top of the flywheel... I will go look at the bolt to check the numbers, will post numbers soon
flyingscott
Sorry it;s an 18/20/25 hp merc, sticker on the recoil won't help you. Silver welch plug might
zackduncan40
Also can one of you tell me what that circled thing is? There isn't one on my 25 hp evinrude so I wasn't sure what it is
zackduncan40
Do you think it would be possible to put an electric starter on that motor? If so what all would I have to get to do it?
