Engine Tapping
brodie123
Hi Everyone;
I rebuilt my Mercruiser 205 inline 4 - 165 hp inboard a year ago and she ran beautifully. (Dual engine in a 30 ft cabin cruiser)
That is until a line fell off the stern and wrapped the prop - luckily at low speed.
After that though, the dreaded "tap tap tap" noise.
I pulled the plug on cylinder 4 and the noise went away. The other 3 had no effect.
I pulled the engine and the rockers, lifters and rods all look fine.
I could not find any play on any piston - tapping lightly with a small mallet.
I removed the piston caps for cylinder 1-3 and all looked fine.
I removed the piston cap for cylinder 4 and the bearings 'popped' out rather than staying seated. Ooops, I forgot to check the torque on the piston cap bolts prior to removing to see if they stretched.
There is 'no' damage that I can find at all - not even a scrape.
I am assuming that the piston bolts stretched? Should I be looking for anything else?
When I re-assemble, new bearings is obvious. But what about the rod bolts? Do I replace?
Any guidance here is appreciated - I don't want to put it back in and hear tap tap tap. lol
thx!!!!
kmarine
I would replace them while everything is appart. This way you don't have to worry about it.
flipbro
You could try new rod bolts. New bearing and some plastgauge to cheak bearing clearances. I personally would check the rod big end for roundness as well. Especially after new rod bolts are installed.
Ayuh,..... Does the 470 use pressed pin pistons,..??
I'd bring that rod to a machine shop, 'n have it checked, 'n resized,....
collapsed piston would also cause a tick. what ever you find, you also need to find the cause. Did the motor ever overheat?
no, collapsed piston from overheat - skirt collapses and piston rocks in bore. Very common piston failure. collapsed lifter is another type of tick - usually due to dirty oil.
