slimdaddy45
- Joined
- Jul 11, 2007
- 45
I need to replace the transom in my boat it has a 1'' wood core but I read that everybody puts 1 1/2 '' in should I do this or leave it at 1'' which would be close to 1 1/.2 with the outer & inner skin its on a Seas Sprite tri-hull if I go thicker not sure if the cap will fit the way the splashwell is made so is 1'' enough since it came from the factory that way it has an 85 hp motor .I will be using marine grade plywood 5ply which would make it 10 ply . the splashwell drain was broke and it only has rot in the center of the transom
