Sae J1171 Marine
Robert Such
Just bought a Regal Valanti 240 & educating myself with all the parts. Does the SAE J1171 marine operate the trim tabs or motor tilt? Does it take ATF fluid?
Howdy
SAE J1171 is the standard by which marine electrical components are made to http://standards.sae.org/j1171_200406/
If your seeing this on the starboard side and at the transom with a gray and black hydraulic lines, this would be the trim pump
If it is mounted and has all black plastic hoses, this would be for trim tabs
Robert Such
Hi,
Its located on the transom, port side of center. It has a black & gray hose. I tried to upload a pic - an attachment, this is my first post on iboats, but I keep getting an error.
Thnaks!
jbcurt00
A pix posting tutorial is available under the Forum rules and guidelines sub-forum, which is linked in my signature line below
Hi,
Thnaks!
In most cases the trim pump is on the starboard side but can also be on the port, so it's probably the trim pump. It will look like this
thumpar
The j1171 just designates that it is marine rated. It should be on all electrical parts. It took me awhile to figure that one out. Take a pic and use a service like photobucket to post it up.
Robert Such
That's the part! I feel like a real newb but does that pump operate the actual stern drive tilt or the 2 trim tabs?
Ayuh,..... Welcome Aboard,...... That pump runs the drive up, 'n down,.....
If ya got Bennett trim tabs, look for a opaque, 'n dark tinted covered little pump, probably plumbed with black plastic lines,....
It'll be squarish lookin', 'bout 4" x 5" x 5",...
Atf, or other light oil, will work in either pump,....
Robert Such
Hello! I've been busy putting new galley cabs in my Valanti, looking good. Now I'm looking for the canvas camper top & frame for this thing. Seems Great Lakes patterns go back to '93 & mine is a '92 - "missed it by that much" (pointer & thumb apart 1")
Ayuh,.... Call 'round the local canvas/ upholstery shops in yer area,....
Most all canvas coverin' is Custom made,...
GA_Boater
Robert - You really should start a new thread about the top. This section is for Mercruiser stern drives and you will have a better shot at answers in one of the general boat topic sections.
BTW - Bondo is right about probably needing a custom top.
Robert Such
Custom top is probably the way to go. GA, sorry, my bad, should have started a new thread, thanks all.
Robert Such
No Title
Back to the engine, can anybody help label & define the workings of #1 & #2 in my pic?
GA_Boater
Wrong pic link to Photobucket - Not working. Click the IMG code box for the pic in PB and paste into a message. That way works better.
