foodfisher
- Joined
- Feb 18, 2009
- 3,756
Don't forget the belt to help reseat the bead.
I worked my way through college doing this stuff in a shop 45 years ago. If anyone who did it recalls, you spin the tire on the balancer , adjust weights, repeat until the bubble stays centered as the tire rotates. That's dynamic balancing. Today's high-speed dynamic balancing process is more exacting and less labor intensive, but just how much does it add to the life of a tire? And, who here has their tires rebalanced after they're installed? I never have. The OP plans to do just that when he rotates them. IMO, his tires will last just as long.
My .02
My .02
The method your describing is dynamic, so is a spin balancer, but some were just stationary and you added weights till the bubble centers up. Those are static , and that is the type I think the OP is talking about.
Huh? I thought that was what starting fluid was for.Don't forget the belt to help reseat the bead.
I learned to use spoons about 45 years ago. I was young and healthy and it was fairly entertaining. I never got anywhere near as good as the old wrinkled guy who taught me. He'd bust a tire before you could draw your second breath. Put the new one on about the same way. Old Jonesie. Quite the character.I use spoons and a manual bead breaker. I can dismount a tire and have another one mounted in less than 2 minutes. Its all about technique.
I had an old fellow tell me to take the valve out and drive over the tire next to the wheel to break it loose. It doesn't always work, especially if the tire is rusted to the wheel. It doesn't take long to see if it works however.
Of course that's not as much exercise.
Pounding with a big sledge being careful to not hit the rim is a lot more exercise.![]()
To borrow a username (Boom ya) Never had the guts to try it.Huh? I thought that was what starting fluid was for.
I have seen these in use:
http://www.northerntool.com/shop/too...1163_200451163
Never seen the ether method and not sure I want to be around when they try it.
Well I got a chance to try it out. Tires unmounted very easily and mounting new tires on rims was no problem at all. The BIG issue was that I was unable to seat the beads to air them up...so in the morning I will carry them to a tire shop. Oh well, the agony of defeat!
That's what I have always used as well. Changed many valve stems over the years and had to do this many times.Good quality ratchet strap around the tread normally will change the geometry of the tire enough to allow it to seat with the air compressor.
