skydiveD30571
- Joined
- Feb 13, 2012
- 1,042
I pull a 21' (~3,500lb) behind a 2011 silverado with a 5.3 (albeit lifted) and get about 8mpg on a calm day on level road. Just part of the experience I guess!
In the pic it looks like the trailer is longer than the boat, so it could be from another boat. Might need to make some adjustments
Sorry to leave everyone hanging. I had a very long day with the seatrial and long drive home, which was made longer by my new 22' friend tagging along behind me.
In the pic provided, what looks like cracks in the repair is just some surface scratches above repair and there is not blistering in the hull it is all water drops. The pics are deceiving.
The fire extinguisher in the engine bay is indeed automatic.
So the issue I had while driving home is literally watching my gas needle drop as I drove. I knew my mpg would suffer, but not like this. As brought up by a few people on a separate thread, the boat is not sitting right on the trailer. The boat is too far forward which is causing the weight to be unbalanced and shift forward. This puts way too much weight on the tongue and drags my car down. It also puts most of the load on the front axle of the trailer and little on the back axle. The bow of the boat is sitting too close to the ground as well (related). The only fix that I see is to move the trailer upright that holds the winch and where the boat sits (what is that called?) back. The question I have in regards to that is, is it ok to move that. It looks like it is made to be moved, but right now it is sandwiched on either side of where all of the joints come together and if I move it it will not be. Does that make sense? I will try to post pics in a minute.
Not when most of the load is on the front axle.I agree but still a tandem so should be ok load wise
They prob moved post foward. Look for marks when it would have been.Also, if the trailer was made for a smaller boat, wouldn't that put a smaller boat further forward and make the situation even worse?
