let me get this straight vortec heads on pre 85 sbc
mxcobra
my setup is 898 sbc 305 already frankensteined. my pistons and valves are getting tired. So if I get a pre 85 shortblock 350- I can put new vortec heads on with the correct intake manifold. Then everything else will bolt up for a fabulous running engine?
Rick Stephens
Don't forget correct lifters, pushrods and rockers. Valve covers as well.
mxcobra
ive found compleate vortec heads brand new for 350 each, if they bolt up that sure be the way to go
flipbro
Absolutely. But as Rick mentioned you need self aligning rockers . 7.793 length push rods if running your flattapet cam. Be sure the last 3 numbers on the heads are 906 or 062.
NHGuy
Once you get it sorted let us know what carb is on there. I have some info you could use resetting the carb if it's a Weber, Edelbrock or Quadrajet.
mxcobra
It will be this winter, going to limp her through the summer - definitely upgrading to a four barrel carburetor. SO Any of those should do I think quadajet. Are the cheapest
Ayuh,.... I'm a big fan of the AFB carbs, the ones Merc is still usin', same as the Edlebrock,.....
Rick Stephens
I have never seen an easier to tune carb than the Edelbrock 1409 right out of the box. Same as the Weber, exactly. And uses the same parts as the Weber off the OEM drawings. Nice when you don't want to have to recreate something from scratch.
