spoilsofwar
Thread starter- Joined
- Jun 29, 2011
- 1,124
Hey all, I have two compartments in the cockpit deck of my boat; a cooler and a "ski locker". I use the quotations because you could never get a waterski in the larger compartment, it's much too small. I use it to store a few plastic boxes holding paper plates, napkins, grill tongs, and things like that.
Anyway, the cooler is plastic, which is smart. It drains to the bilge. I don't use it as a cooler, but I throw a Walmart plastic bag in it and use it as a trash can.
The ski locker, on the other hand, is carpeted. A stupid surface for in-floor, considering there is no carpet anywhere else on the boat except the cabin bulkhead. it stains, and retains water, and smells, etc.
I'd like to tear out the carpet (which would be easy, it is just glued down and stapled around the edges) and resurface it with? To make it somewhat smooth and easy to clean out. It also has a drain to the bilge.
Under the carpet is rather rough fiberglass. So the question is:
What would you use to smooth and surface the compartment in order to make it easy to clean out?
