85 470 runs the same on 3 cylinders as 4
ctaylor2069
I was checking for spark and I pulled boot off #1. Cranked over and engine fired and ran. On 3 cylinders. No miss or rough idle. Put back together and it ran fine. Then later felt like no spark again so I pulled boot #1 to check for spark, same thing, started and ran fine on only 3 cylinders. What is going on
jimmbo
It's running on 3 cylinders. Did you have spark on the suspected dead cylinder?
If no; What condition plug wires? Distributor cap?
If yes: What condition is the spark plug. Does that cylinder have compression? Leaky intake manifold, broken hose? Are the valves opening and closing?
stonyloam
Do a compression check. In the meantime pull the other wires ( from the distributor cap) one at a time and see if the idle drops significantly with the other 3 cylinders. If it does then #1 is the problem. Take the plug and wire from #2 and swap them to #1, (you know #2 wire and plug are OK) see if this changes anything. If not then the problem is internal with #1, probably low compression, head gasket or valve. Check the color of the #1 plug vs the others. The compression test will confirm. Good luck.
ctaylor2069
Thanks for getting me started in the right direction. But can someone explain to me how it's possible for the engine to run so smooth in only three cylinders?
ctaylor2069
Ok I'm going to do a compression test either tonight or this weekend
Alumarine
There may be nothing wrong.
As someone suggested try your test with the other cylinders.
It would be different if it ran the same when you were out using it.
jimmbo probably nailed it.
