fixmyevinrude
Thread starter- Joined
- Sep 18, 2008
- 205
1988 Evinrude 150 XP
I plan to time my motor using Joe Reeves WOT method. I plan to use 12 inch jumper wires with14 gauge stranded copper wire and an alligator clip attached to each end. I will remove the 6 spark plugs and plug wires completely. I then will attach the jumper wires directly to 5 of the 6 cylinder coils and an engine ground. Then I want to rig a spark tester to the number 1 cylinder and proceed with the timing operation. I just want to make sure that I wont be damaging any componets with the method I mentioned above. In paticular the jumper wire set up I plan to use. Thanks for any feedback or ideas.
