jamespjackson95
Thread starter- Joined
- Jan 21, 2012
- 30
Okay guys so I recently purchased a 1997 sylvan 20' boat with a 5.7 carbed mercruiser engine. The boat runs great except the gear lube reservoir leaked pretty fast on our fist lake outing. I mean the reservoir was full, and empty in about an hour. When I noticed it got to the bottom of the reservoir I put it back on the trailer and headed home.
I noticed that most of the bellows were trashed so I removed the lower unit to begin replacing parts. I noticed that not only was the gear lube low, there was also water getting into it making it milky colored when I drained it. There was water in the large u joint bellow so I am replacing the gimbal bearing as well... Anyways today I pressure tested the lower unit while it was off the boat... I sent about 15-20psi of pressure and immediately noticed bubbles here... I assume I have to tackled this by removing the top plate on the out drive but I was looking for someone who knows what tools I may need to replace that gasket/seal and what the part number for the seal is called so I can order it. Is this a common place for leak? Air was coming out around the shaft.
