loco
Thread starter- Joined
- Apr 25, 2010
- 154
Hi all,
So I've been getting milky oil in the rocker covers. The oil in the sump is fine, and the engine is only 2-3 years old, so I'm pretty sure it's nothing serious.
The engine uses raw water cooling, and sea temp here is between 8-15C (46-59F) so runs a bit cooler than closed cooling, so won't burn off as much moisture.
There are breather hoses in each rocker cover, with something like a 1/2" pipe coming from each of them, and they're fairly crudely attached to the air filter. I'm pretty certain that when the engine's been cooling down, it's been drawing in a load of damp, humid air with it, which is causing the nasty oil in there.
What are the potential solutions here? I'm thinking some kind of filters on the breather pipes to prevent humidity getting in, or something similar.
Any ideas very welcome!!
Thanks in advance.
Thanks in advance.
