saltydogjeff
Thread starter- Joined
- May 12, 2013
- 145
I am trying to recover/restore a boat to working order. Whatever happened and I got this boat on my hands and is not currently running. Anyways...
This boat is like a bird's nest with wires. I have the electrical diagram for the engine components, gauges, and switches. I am basically rewiring all the auxiliaries.
My goal in this wiring mission is to save the batteries. There are two wired in parallel to one of those rotary switches with the 1, 2, or both option. I would like to be working downstream of the switch (or the key switch) to assure that the batteries stay at full charge.
Now I am looking for comments, recommendations, personal experience on how to wire the auxiliaries. Are there loads that are required to be directly connected to the battery? I believe there were about 3 loads that were always connected to the battery: trim pump, bilge pump, and an auxiliary fuse board. I understand the reasoning behind the loads,but the wiring looked dangerous. What about the navigation or mooring lights when anchored? I think I might just hook all these loads up to the auxiliary fuse board, but that is also like wiring power lines all the way forward and then all the way aft.
Thank you.
Thank you.
