"The Works" toilet bowl cleaner is sold at Home Depot and Walmart, it's dirt cheap at about $1.50 a quart or so. It's essentially muriatic acid (hydrogen chloride)...
I've used it for years. Thing is, in the past couple of years they've been changing the percentage of actual acid. For years it was 20%. I've since seen it at 14% and even 9%. Check the bottle, it'll say on the bottom...
The other option is to just buy muriatic acid. But-- I was looking at a gallon at HD the other day, and nowhere on the label did it state the acid percentage. This is handy to know, for dilution and for your money's worth...
Here's what I know, and how I use it..
First, it's only good on calcium deposits. It doesn't clean algae or dirt. Likewise, stuff that will clean your dirt won't much remove calcium.
It's safe to use on most aluminum, like your outdrive, as long as it's rinsed quickly.
50 series aluminum used to make pontoon logs isn't affected.
DON'T get it on anodized aluminum, OR stainless steel. It will etch anodized, and it'll darken stainless. Keep it below the rub rail and dive deck and you should be ok.
Dilution- 20% acid can be diluted 4 to 1 and still work okay, but I like it a bit stronger, say 8 to 10% as an end result. This is why you need to know how strong it is in the first place. If you find 9%, just use it straight--
Application: Get a cheap $9 garden sprayer from Low Depot. This and a garden hose with an on/off trigger sprayer is all you need. No brooms, rags, brushes, nothing. Honest!
Procedure: First, pressure wash everything off you can. Like I said, acid won't clean dirt.
Get some rubber gloves on. Mix your acid and water in the sprayer, and pump it up. Have the garden hose ready and waiting.
Work about a square foot or two at a time. Pick an area that big and spray. You'll know it's working because it'll create smoke while it's burning thru calcium.
This is important- The calcium you're spraying will neutralize the acid in about 5 seconds flat. SO, spray, wait 5 seconds (watch the smoke), spray again. You'll be amazed as you watch the calcium melt away. After about every 4 sprays, douse well with the water hose. If you keep seeing smoke, keep spraying until you don't. Then move on. You'll find a rhythm where you just slowly keep moving, and you'll be done before you know it. No scrubbing, just spray a few times, rinse well, repeat.
I did my 26' Chaparral last year, took about an hour to do the whole boat, and 2 quarts of 20% 'Works'. It was pretty bad and looked like new when I got done. My dock neighbor who usually pays a couple hundred bucks to have this done to his 27'er was stunned.
Muriatic acid won't harm your lawn, or driveway. I've had no trouble with it on my trailer, just keep the water flowing!
Remove unused acid from the sprayer and rinse it and the nozzle with water. The acid does them no good, which is why you buy cheap ones! (I get about 3 or 4 uses out of one)
I'm sure other stuff works, but spray n' rinse and be done-- works for me!
