Hey guys,
I havent posted in here in a long time. I got rid of my 115hp and went to a proper amount of hp for my boat. I got a steal on an 1984 black max 150 runs perfect smooth and strong. However id like to put either a water temp gauge or water pressure gauage. Ive look into to it but struggling to find a clear description of what to do. Ive also found that a water pressure gauge may be better or more reliable than a water temp. For the water temp i found on forums that there is a spot right under the flywheel that has a cap in it for where the water temp gauge fitting goes. I have pictures of what i think is this spot and will attach. Also im trying to figure out how to get a trim gauge working. The trim works perfect and there is two wires coming off the trim assembly other than the ones that goes to the trim pump. Are these two wires for a trim gauge?
Thanks for your time guys!
