jackmorgan
Thread starter- Joined
- May 5, 2016
- 43
Hi, Just put my 'new to me' 2007 four winns vista 258 in the water today. Tested engine and transmission before putting it in the water. Everything is fine with no load - revs to 5500 and idles perfectly. When out on the water it seemed fine up to 2400 rpm (approximately) but wouldn't go above that with WOT. There was some vibration above idle, but nothing too bad. I just changed the ujoint and exhaust bellows, but the alignment tool was backordered from volvo so couldn't do it. What could be causing this? Limp mode? Could a vibration from misalignment trigger limp mode? Just a little more info - the boat was sitting for 18 months. I drained and refilled the fuel, changed the fuel filter, oil, gear oil and everything else in the service manual. Only 70 hours on the boat. Volvo penta 5.7 Gi-G engine with DPS-A sterndrive. Any help would be appreciated. Thank you.
Jack
Jack
