urbanredneck
Thread starter- Joined
- Mar 30, 2016
- 111
Hi guys. I know this is a very common subject. I've spent hours pouring over the internet looking for ideas, haven't found anything specific enough that relates to what im working with. I own a 87 Mirrocraft Northport Troller. Similar to the photos. I Have a casting platform at the front. Also has a V shaped piece of aluminum attached to the two halfs of the boat up front with a nav light on top. I figured id just build a very simple box to elevate the space between the platform and the edge of the boat,with a 2x4 coming off that over the edge and attach the motor to that. Doesn't sound very secure to me. I would also like the option of a quick release pull up mechanism to pull the Minn-Kota up out the water when approaching obstructions and/or motoring with the main motor. Short of using some type of door hinge, im lost. Iv seen the "gator mounts " ( i think thats what they're called) , made by Motorguide which is essentially what id like to build. They are spendy and very complex. Was hoping for some ideas. I currently have the motor mounted on the front side of the bow, at the 1 o clock position with a small piece of wood on each side of the clamps. It works. But the motor isnt centered, and bounces around a lot while moving. Also requires completely un mounting if i want it secured enough to WOT. Pain in the butt to say the least. Thanks for any help. These are photos of a very similar boat I got off Google. Not my boat. Again, thanks
