Fuel Line connector getting too hot
Perhaps a cylinder sleeve is loose and has rotated out of position.
ondarvr
On a two stroke the fuel and air mix travels from the crankcase to the combustion chamber through the ports in the cylinder wall, depending on the exact positon of the piston these ports are open pathways. When running lean the flame front can travel back down through the port and ignite the fuel still in the crankcase.
Marcel Cloutier
Any suggestions on how to fix this?
ondarvr
As I said, put your hand over the carb to restrict the air slightly to that cylinder, if it stops the sneeze and runs better you know it's running lean. After that you need to figure out why, which normally starts by inspecting and cleaning the carb.
Marcel Cloutier
Ok, thanks. I cleaned the carb originally because it wouldn't start. That fixed my problem of not starting but I guess i need to research how to adjust the carb for the proper mix. Will keep working on it.
sam am I
Sam I am asked the same question you did about how combustion could take place in the crankcase. Not sure why he deleted it.
I had noticed just as posting we had asked same exact question, thought, why ask same thing twice? and deleted it.....apologies if I confused the issue.
Seems though, as I think about it more, that's a lot of sneezing going on to roast those connectors......hmmmm. I don't know his engine thou but, doesn't his engine share the same carb. for all three cylinders? And if it was the lean carb. problem causing it, wouldn't/shouldn't all three cylinder be sneezing?
If they should be then based on that logic, and to confirm that was in fact the case, then perhaps looking at the other two holes somehow to see if their sneezing away would in fact point back to the carb. as the issue....
Also thinking "what if" that hole every once in a while had a false trigger? Due to like a flaky pick-up, trigger coil, switch box booger, loose johnson rod, whatever but, when it false triggered, the plug of course fired and the piston, as ondarvr said in the sneezing situation, the piston was at such a point in its stroke, the fuel in the lower side was opened just enough via the cylinder wall porting, it gets ignited?
Just thinking out loud and perhaps both above thoughts can be simply and cheaply either eliminated or confirmed before a major rebuild.
Off to Krispy Kreme's...I think the light just came on!!! ;)
Marcel Cloutier
Just figured I would give you guys an update on my issue, and anyone else who may read this because they have a similar issue...
If you decide to take the carburetors off a 17 year old motor, make sure you change all of the gaskets when you clean the carb. Don't skimp because the new gaskets are cheap from this place.
Turns out that is all I needed to do. Carb was getting too much air through bad gaskets. Once I replaced all of them, it is running and I have no more "sneezes". Since this was my first motor job I'm glad I went through the process because I learned a lot, but if you're just looking to fix your problem, rebuild your carbs and don't just clean them. Lesson learned. Thanks for all the help guys.
sam am I
No doubt and a priceless update at that!!...........Melting fire snorting pulse hose connectors = Bad carburetor gaskets.
Crazy stuff........Still wonder if the Merc eng's ever saw this potentially happening when they tapped the lower ends to drive the rubber fuel pump diaphragms? Maaaaaybe they did and used a nylon/plastic connector as a tell-tail.....hmmmm, nahhhhhhhh!! Might be behooving to inspect that pump's diaphragm at the other end of that pulse hose, its probably okay but........
Marcel Cloutier
Well I had rebuilt the fuel pump before the fire
Breathing dragon showed up but I see where you're coming from. However.... Since I have it running, and have readjusted the idle pins so it running good, I think I'm just gonna go fishing 😀!
I really do appreciate all your help guys. I'll definitely be back if I have any more issues.
GA_Boater
I doubt Merc saw this potential. And doubt Merc thought tearing apart a carb and putting it back together without new gaskets should be in the maintenance procedures.
I hate seeing cleaning carb posts with no mention of parts.
Glad you got the dragon cooled off, Marcel. Catch some fish!
Thanks for the update. I wish it happened more often.
sam am I
And doubt Merc thought tearing apart a carb and putting it back together without new gaskets should be in the maintenance.
Hehehe, funny GA, not specifically Mr Cloutier's actions!!..........I highly doubt they could have predicted that but, ya never know tho...... Nah, I was referring to the evidently lean condition/sneezing as brought up by ondarvr in more general terms of carb issues/adjustments causing such a thing to happen.
Thinking back, I've ran/was too lean and have been sneezey, specifically while dialing in and the term also coming up here and there from time to time...... Was just blissfully unaware of this potential at this/his level blowing into and through the fuel pump pulse hose......Perhaps it's one in a million, not sure.
And GL fishing Marcel!!
