JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,769
As part of a bellows job, I'm replacing my lower shift cable. Unfortunately, I was following the manual and it makes no reference to leaving behind the shift cable core or some other sort of line to serve as a fishing line to pull thru the new shift cable. So, I've been struggling with getting the shift cable through the transom and into the engine compartment.
After lots of contortions, I've got the cable thru the transom and under the starboard Y-pipe. I'm not sure the routing is correct, though... the manual (see below)shows the shift cable going UNDER the starboard motor mount, but in my case, it's going up and over the mount. In fact, I can't see how it would fit below the mount... the engine/coupler would be in the way.
I'm trying to figure out if my routing is OK, but I can't find pictures, etc. online that clearly show the shift cable routing with the engine installed. As is, the cable doesn't seem to be making any sharp bends, but I'm concerned that it comes out of the transom plate and bends up, instead of of coming straight thru as the manual diagram seems to show.
Anyone have a good, clear pic of the cable routing for a Gen 2 on V8?
Thanks!
Thanks!
