kccoe
Thread starter- Joined
- Jul 4, 2015
- 62
I had a bearing to go bad in lower unit and the mechanic replaced and flushed system and new gear oil. I even provided the Volvo gear oil. One problem he forgot to add gear oil and remove the flushing fluid. After he said I was ready to go repair is done I ran boat for 1 hour and then overheat due to seals giving way and sucking air on plane. I got home and check out drive gear oil and the picture says it all. Out drive smell like burnt oil and roars. He says may have not hurt gears and bearings he will replace the seals and add gear oil and good to go . I think he is just hoping to not be out about 5500 . I am no fool. I say he owes me an remanufactured outdrive. I am very upset. I think the outdrive is total loss . Any suggestions or thoughts.
