striperday
Thread starter- Joined
- Jun 2, 2011
- 23
I have a 2003, Crestliner 1850 Fish Hawk DC. Im not the original owner. The wood needs to be replaced on the Transom. Any help would be appreciated.
I made a call to Crestliner to learn that the boards are 5/8" and its three layers laminated together. Well I can not find 5/8" at any of the lumber stores in my area. I can however find 19/32" board everywhere. From what I am learning the Nominal size is called 5/8" but to be more precise its actually 19/32". The difference is 3/32" Total width. If I find out that I am wrong and I actually can buy 5/8" board and it must be used in my boat I will have to find some type shim to use I guess. I hope Crestliner was correct about being able to use the 19/32" board. I went ahead and purchased the boards, Laminated them together using TiteBond3 as recommended and have cut the new transom out. Here are a few pictures. The pictures show the old board as if its one piece but actually they are just laying together as I placed them that way. The old transom just fell apart in the middle it was so deteriorated and rotted. No paint at all on the old transom nor were any of the bolt holes filled with any type caulking. Well am I in trouble for using the 19/32" board?If his transom "sleeve" is anything like mine, it will be hard to paint it. Maybe use a 4" roller and a brush on a stick to prime and paint. They sell a roller handle called a long John for getting behind toilets that is long enough to get down the channel to prime and paint. Not a bad idea since you have the corrosion going on. Mine didn't have any corrosion at all so I left it but hind sight tells me I should have finished it since it was apart anyway.I forgot to mention, see that white on the old wood, that translates into corrosion on the inner transom skin. Be sure to clean it all off there, skin the pitting with MT or JB, prime and paint before installing the new wood transom.
