Re: Engine change , port charlotte/punta gorda
They are actually pretty easy to remove. Pull the upper gear box on the outdrive. Remove the 6 bolts around the ring. Remove the 4 lag bolts holding the front engine mounts to the stringers (No don't leave the mounts on the stinger, you will never get it back together without damaging something).<br />Then disconnect the water inlet hose, the electrical cable plug, battery cables, throttle cable, fuel line and lift it out. Hour to hour and a half max.
