flynavy812
Thread starter- Joined
- Jun 12, 2016
- 13
Hello everyone, I'll try to keep this brief. Acquired this engine with a small john boat, previous owner was very clear about potential seal issue. Said lower unit seals are "bad" and gear lube leaks. He stated that everything runs fine and that he just replaces gear lube every 5-6 trips, and it shouldn't be a problem on this engine. He also mentioned he had someone come out to "fix" the issue but nothing really changed.
Skip forward, I finally took the boat out and everything ran just fine. I know this is probably a bad idea, but to be honest I don't want to dumb a lot of money into this, and I might have to sell in a few months if I need to move for work. So I put fresh gear lube in prior to the first trip to be safe.
So, initially I could see gear lube leaking out of the drain screw area, upon the first draining I realized there was no gasket so I was hoping this would be an easy fix. Added new gasket after filling up with fresh lube. Let it sit overnight and no more leaking from the drain screw area, or anywhere else.
Next day I notice gear lube is now "leaking" NEAR the vent screw area. It might be hard to tell from photos, but there is a very very small hole near the vent screw/bump looking thing in the photo. Upon closer examination, I can see what appears to be rubber/gasket material kind of blocking the hole. So I'm not sure if this is supposed to be sealed? Maybe a gasket to the other part of the lower unit is bad, allowing gear lube into this area, where lube would normally not be found?
So here is my problem, everywhere I've called said it will be a roughly 2 hour job, at around 90.00 per hour in labor. Am I an idiot for thinking I should just keep running it, while being diligent on the gear lube levels?
Should I just look for another lower unit? Are any other lower units compatible with the 8HP I have?
Should I just look for another small used motor in good condition?
This engine is in great condition other than this one fault, a lot of things have been recently replaced. I just don't want to dump too much money into an already cheap project, but I also don't want to get stranded if something goes bad. Any advice is appreciated, if any other photos are needed I will get them ASAP.
