I did some experimentation, and I think the fuel pump is ok and maybe located the problem area (or at least indication), hopefully that can be fixed.
Was wondering if the float valve was malfunctioning, the fuel pump would be flooding the carb. I tested by disconnecting the cap where the fuel filter is and put the incoming fuel line in a collection cup. I pulled the engine start rope it did pretty much the same thing, not starting unless the throttle was on fast. In the mean time, a fair amount of fuel spurted out of the line from the fuel pump, into the collection cup.
I'm assuming that the engine can run without the fuel pump, as long at there is fuel in the float bowl. Is this correct? I don't want to be testing in a way that won't work any way.
Anyway, here is where I am.
The carb always has been wet in the throat and a little puddle underneath, on the motor frame. maybe it was doing this all along, but now I notice fuel dripping off the end, of the shaft for the throttle shutter.
Will look to see where the fuel is coming from
