estes82
Thread starter- Joined
- Jun 16, 2016
- 10
1999 75hp Force (need help finding the neutral safety "switch" so I can jump it)
I am going to check my timing on my 1999 mercury/force 75hp outboard 2 stroke. My 1997 Sun Tracker Party Deck has a 41 gallon tank that I successfully ran dry last weekend using the Quicksilver Quickcleen #2. I just got the boat in November and I have no idea how long that gas had been in the tank. Ran well at top speeds however to start it I did have to advance the throttle. Advancing the throttle is not something I have done the first couple of times I took the boat out to get it to start, so it might have just been the fuel treatment. I am aware from reading many threads here that this engine should have the cold start setting on its own if the timing is set correctly. However I had played around with the idle settings and changed the starter and have turned the flywheel a few times in aggravated displeasure when my rebuild of the starter failed me lolol...
So anyways, after reading many threads and watching some of the videos, Franks especially, Im going to check the timing by grounding the wires and have my wife crank it at WOT. I just for the life of me can figure out where the neutral safety "switch" is?...
Also I don not have any good photos, the boat is 3 hours away at the moment. I left it parked at the cabin down at Lake Barkley. So a diagram would be good or really a good explanation, as there are no a lot of parts that I have not cleaned on this engine... grounds etc...
